Navy Federal Credit Union
Last activity: 16 Sep 2020 12:41 EDT
Interrogation on Web Application not working on IE11, Win 10, Pega Robotics Studio Version 19.1
I am unable to capture any web controls for any websites in IE, Chrome & FireFox.
When I click on Interrogate, I am getting the normal interrogate dialog box which we get when capturing any windows controls.
It only captures the outer browser window and not any web controls on the webpage.
With a new version of windows 10, you will need to update the PRS version to 19.1.50 or .51 to account for new security settings with Windows. If you have access to Pega community, you can navigate to the Robotic Process Automation page to request the newer version.
https://community.pega.com/knowledgebase/products/robotic-process-automation
I do not see 19.1.50 or .51 version available. Latest version available for download is 19.1
The number after 19.1 is the build version. Here are the build notes. I am not sure what you see as a customer, but when I request a download, it asks for the build number.
https://community.pega.com/knowledgebase/articles/pega-rpa/pega-robotic-automation-build-notes
This is what I see when I click on given link
You can click on Pega Robotic Automation 19.1 to see each build version and the notes about it. This is not where you download them to be clear. When you download from the Digital Delivery Portal, you should get an option to select a specific build.
@sasnt @lambm : Below is info about installed version. Attached is the screenshot where I cannot see "Create Global Web Page" checkbox when I start interrogation for Web Adapter.
Pega Robot Studio Version 14.0.25420.1 D14REL Microsoft .NET Framework Version 4.8.04084
Installed Version: Express
Pega Robot Studio Proprietary information hidden
I just found out that MS put quietly pushed out another security update. The easiest means to get around that, if you cannot get access to 19.1.50+ is to delete the current ACME web adapter from the ACMESearch project, and add back a Universal Web Adapter, assuming you have Chrome or Firefox. This is a temporary workaround until a fix can be found.
You will need to add training.openspan.com with 'contains' as the Regex rule to the accepted domains on the UWA properties window.
