virtusa
Posted: Mar 29, 2016
Last activity: Mar 30, 2016
Last activity: 30 Mar 2016 4:32 EDT
I suggest that you check the rule names where you are associating the rules with one another. Your screenshot shows "TicketRespone1"
Perhaps this is a typographical error, and you meant to type "TicketResponse1" somewhere?
sry jeff i am not able get u can u elobrate it ????
Jeff suggested to check/verify the rule name's as you were getting Failed to Open record.
ya i got the output i am not able specify the xml parse num correctly thanks fro the response
You are welcome.
