FedEx Integration
I am getting the following error when I attempt to leverage a SOAP connector to a fedex webservice, and I have already done the workaround at https://community.pega.com/support/support-articles/parse-xml-referred-service-soap-works-incorrectly. Any assistance would be greatly appreciated.
| Embed-Error | |
| <detail><cause>UnrecoverableClientError</cause><code>SchemaError</code><desc>validation failure for ProcessShipmentRequest Error:cvc-elt.1: Cannot find the declaration of element 'ns1:ProcessShipmentRequest'.</desc></detail> | |
| Fault | |
| Fail | |
| com.pega.pegarules.pub.services.RemoteApplicationException: SOAP service failed | |
| Fail:InternalReason |
Autogenerated XML from the XML Stream Rule.
<pega:withEmbedded name=".ProcessShipmentRequest"><ns1:ProcessShipmentRequest xmlns:ns1="http://fedex.com/ws/ship/v17">
<pega:withEmbedded name=".WebAuthenticationDetail"><ns1:WebAuthenticationDetail>
<pega:when test="$is-present(.ParentCredential)"><pega:withEmbedded name=".ParentCredential"><ns1:ParentCredential>
<ns1:Key><pega:r n=".Key" m="normal"/></ns1:Key>
<ns1:Password><pega:r n=".Password" m="normal"/></ns1:Password>
</ns1:ParentCredential></pega:withEmbedded></pega:when>
<pega:withEmbedded name=".UserCredential"><ns1:UserCredential>
</ns1:UserCredential></pega:withEmbedded>
</ns1:WebAuthenticationDetail></pega:withEmbedded>
<pega:withEmbedded name=".ClientDetail"><ns1:ClientDetail>
<ns1:AccountNumber><pega:r n=".AccountNumber" m="normal"/></ns1:AccountNumber>
<ns1:MeterNumber><pega:r n=".MeterNumber" m="normal"/></ns1:MeterNumber>
<pega:when test="$is-present(.IntegratorId)"><ns1:IntegratorId><pega:r n=".IntegratorId" m="normal"/></ns1:IntegratorId></pega:when>
<pega:when test="$is-present(.Localization)"><pega:withEmbedded name=".Localization"><ns1:Localization>
<ns1:LanguageCode><pega:r n=".LanguageCode" m="normal"/></ns1:LanguageCode>
<pega:when test="$is-present(.LocaleCode)"><ns1:LocaleCode><pega:r n=".LocaleCode" m="normal"/></ns1:LocaleCode></pega:when>
</ns1:Localization></pega:withEmbedded></pega:when>
</ns1:ClientDetail></pega:withEmbedded>
<pega:when test="$is-present(.TransactionDetail)"><pega:withEmbedded name=".TransactionDetail"><ns1:TransactionDetail>
<pega:when test="$is-present(.CustomerTransactionId)"><ns1:CustomerTransactionId><pega:r n=".CustomerTransactionId" m="normal"/></ns1:CustomerTransactionId></pega:when>
</ns1:TransactionDetail></pega:withEmbedded></pega:when>
<pega:withEmbedded name=".Version"><ns1:Version>
<ns1:ServiceId><pega:r n=".ServiceId" m="normal"/></ns1:ServiceId>
<ns1:Major><pega:r n=".Major" m="normal"/></ns1:Major>
<ns1:Intermediate><pega:r n=".Intermediate" m="normal"/></ns1:Intermediate>
<ns1:Minor><pega:r n=".Minor" m="normal"/></ns1:Minor>
</ns1:Version></pega:withEmbedded>
<pega:withEmbedded name=".RequestedShipment"><pega:include name="pyAnyNS.pyAnyName" type="Rule-Obj-XML" inline="false"><pega:param name="pzElemName" value="RequestedShipment"/><pega:param name="pzElemNS" value="http://fedex.com/ws/ship/v17"/></pega:include></pega:withEmbedded>
</ns1:ProcessShipmentRequest></pega:withEmbedded>
WSDL is located at http://cm72.pegatsdemo.com:8080/Fedex/FedExWebServicesAdvancedWSDL/ShipService_v17.wsdl
Tracer Output:
Header Sequence 35 Interaction 480 Timestamp Jul 01, 116 - 11:43:03 11:54:49 (20160701T154303.414 GMT) Elapsed Time 0.0080 (s) Event Type Step End Event Name Step End Event Key RULE-OBJ-ACTIVITY RULE-CONNECT-SOAP INVOKEAXIS2 #20151123T164603.692 GMT Thread Name STANDARD Requestor ID HCA785AAA21C7A10EBAD0698555460AEE Correlation ID HCA785AAA21C7A10EBAD0698555460AEE Work Pool MyCO-FW-HRFrameFW-Work Active PAL Stat pxConnectElapsed Last Step RULE-CONNECT-SOAP INVOKEAXIS2 #20151123T164603.692 GMT Step: 15 Circum: 0 Input Activity=Pega-RunRecord.pzRunRecordExecute Ruleset Name Pega-IntegrationEngine Ruleset Version 07-10-23 Standard Activity Name INVOKEAXIS2 Activity Number 26 Parameter Page Name =unnamed= Primary Page Class Rule-Connect-SOAP Primary Page Name =unnamed= Step Method Java Step Number 15 Step Status FAIL Step Status Info
** SOAP service failed
