installation issue.
Hi Team,
while installing my personal edition of (CSA _7.3.1). i am getting below error, could you please help resolving this.
BUILD FAILED
C:\Users\Prem \Documents\Downloads\115633_PE_7.3.1\pegaGuiInstallerTemp\build.xml:214: The following error occurred while executing this line:
C:\Users\Prem \Documents\Downloads\115633_PE_7.3.1\pegaGuiInstallerTemp\build.xml:82: exec returned: 1
Total time: 23 minutes 39 seconds
org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:90)
at org.tp23.antinstaller.runtime.ExecInstall.exec(ExecInstall.java:87)
at org.tp23.antinstaller.selfextract.SelfExtractor.main(SelfExtractor.java:398)
Caused by: org.tp23.antinstaller.InstallException: Use logs to find the cause, then correct and run again
at org.tp23.antinstaller.runtime.exe.AntLauncherFilter.exec(AntLauncherFilter.java:80)
Show More
Hi Team,
BUILD FAILED
... 2 more
--- Nested Exception ---
Premansu
Show Less
Hi Premansu,
Above error depicts generic error text and as suggested from above logs in console we need to check logs for more info.
Detailed logs would get generated at C:\Users\UserXYZ\AppData\Local\Temp folder generally.
Ujjwal
