Input Parameters Entrypoint
I have a solution which will use a lot of variables from an application. To use these variables I need to work with input parameters through the entrypoint. However it seems I hit the limit of the amount of input parameters. Now my automation is giving errors.
Is there a known limit to the amount of input parameters of an entrypoint of an automation?
thank you,
Marlot
