cognizant
Last activity: 5 Nov 2015 6:56 EST
inbound data mapping failed
Hi
One Service Soap we are using and when .Net team is using this they are getting a error message
Inbound data mapping failed
Please suggest what could be the reason.
Updated: 8 Jan 2024 15:53 EST
PEG
Please share the complete stack trace and Screen shots of Service-SOAP rule .
cognizant
Hi Gangababu,
I can sent you the screen shot of service-soap rule, tell me the process to provide you the stack trace ?
PEG
You can attach in this thread.
Updated: 19 Oct 2015 7:43 EDT
cognizant
We are using Service Soap and when .Net team is trying to use this they are getting a error message
"Inbound data mapping failed"
Below is the XML requested by .Net team.
Below is the log from .Net team side:-
10 01 04:00:17 WVPMA1027 PICASSO_1_E:BatchServices-WCCReasonCode-WCCReasonCodeFeeder-Main Error : System.ServiceModel.FaultException: SOAP service [ManageCNGRefData][ManageCNGRefData][ManageCNGRefData] failed:Inbound data mapping failed
Server stack trace:
Server stack trace:
at System.ServiceModel.Channels.ServiceChannel.HandleReply(ProxyOperationRuntime operation, ProxyRpc& rpc)
at System.ServiceModel.Channels.ServiceChannel.Call(String action, Boolean oneway, ProxyOperationRuntime operation, Object[] ins, Object[] outs, TimeSpan timeout)
at System.ServiceModel.Channels.ServiceChannelProxy.InvokeService(IMethodCallMessage methodCall, ProxyOperationRuntime operation)
at System.ServiceModel.Channels.ServiceChannelProxy.Invoke(IMessage message)
Exception rethrown at [0]:
at XXXXX.CRUSE.WCCReasonCode.WCCReasonCodeProcessor.ConnectToPEGA(XmlNode wccdata)
at XXXXX.CRUSE.WCCReasonCode.WCCReasonCodeFeeder.Main(String[] args)
Please suggest what could be the reason. ?
PEG
Is ResponseIndicator an optional property? You can check the same in Nodes tab of ParseXML/XML Stream rule?
Please share PRPC version also .
cognizant
PEG
Please create Dynamic System settings (DSS) and try out the scenario.
Purpose:StreamXML/DetectEmptyProperties
Owning Ruleset: Pega-IntegrationEngine
Value:true
Updated: 5 Nov 2015 6:56 EST
cognizant
Please find with below word "ManageCNGRefData"
*** REMOVED STACK TRACE WHICH CONTAINED PROPRIETARY INFORMATION ***
PEG
I would suggest you to raise a SR with Pega GCS. I believe it needs further debugging.
Hi dayakar mareddi,
Were you able to open up a SR as requested by Gangababu Gollapalli? If so, please let us know the SR and we'll attach it to this thread for tracking!
Thanks!
