Accenture
JP
Last activity: 14 Aug 2023 22:24 EDT
Impact of IP address changes on Pega
Hi, We want to check whethere the operation of Pega is affected when the IP address of the server on which Pega is running is changed such as disaster recovery.
We built Pega platform 8.8 on our on-premise environment.
When we installed Pega, the DB is specified by domain name.
And we also use a domain name to access our Pega application.
Therefore, even if the IP changes due to disaster recovery, the destination will be changed flexibly according to the domain name.
Is there any part of internal processing in Pega which uses the IP address of the servers as it is?
And does Pega's operation remain unaffected if the IP of the server on which it is running changes?
Hi @KentoO16649593: Please check pr_sys_statusnodes table to make sure records of old IP are removed. Better way would be to bring all nodes down, backup and clean up the table and start the nodes.
Thanks.
