IAC doAction uses QueryString - How to change to POST
We are currently using PRPC7.1.5 with IAC. By default IAC uses POST; however, there is a network request in which IAC sends the parameters to launch the flow via QueryString. The client does not want sensitive data that is visible and to use POST. How can this be accomplished?
***Updated by moderator: Lochan to add Category***
