Chase
Last activity: 10 Dec 2016 13:12 EST
I have a requirement to show few lines of text [also has hyperlink inside the text] , which is help text with "?" shown in the label of dynamic layout
I am using Pega 7.1.8
I have a requirement to show few lines of text [also has hyperlink inside the text] , which is help text with "?" shown in the label of dynamic layout. Once clicked or mouse over, it has to show the text and hyperlink should navigate the url website once clicked. I used field value for other text since has 4 lines sentence which greater than 64 character limit. For this requirement am using Paragraph instead of field values are not supporting html tags am not able to put hyperlink , so i decided to use Paragraph instead of fieldvalue.
I used paragraph and put the paragraph[ tried with/without smart info option in paragraph] inside the section , then refered in the Smart Info control in the action side, so when "?" help icon clicked it should show the paragraph text inside the section which is referred in Smart Info.
But I am getting "Can not render section" as shown in attached file[ see the image attached with this] , please help me .
Advance thanks, Appreciated
***Updated by moderator: Lochan to create new post from this comment; added topic category***
