Ericsson
Last activity: 18 Feb 2016 23:46 EST
I am getting an Issue In Connect SOAP.
SOAP Service Failed.
In Production it is working fine, But in Dev it is not working.
While going through the Tracer For Dev environment The dynamic System settings is fresh.PFA the snapshot.
In Production The Status is good
What might be the reason for this.
Can any one throw light on this.
Is this the reason Soap Service is getting failed.
Thanks & Regards
PEG
Can you paste the stack trace of the error you were getting? And also check EndPointURL is valid in dev env or not
Ericsson
| at com.pegarules.generated.activity.ra_action_invokeaxis2_ab4bacc4d22ff691fd98ed821335eb56.step15_circum0(ra_action_invokeaxis2_ab4bacc4d22ff691fd98ed821335eb56.java:4048) |
| at com.pegarules.generated.activity.ra_action_invokeaxis2_ab4bacc4d22ff691fd98ed821335eb56.perform(ra_action_invokeaxis2_ab4bacc4d22ff691fd98ed821335eb56.java:308) |
| at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3375) |
| at com.pegarules.generated.activity.ra_action_invoke_5e9e0cecbbfdfa9a2b1306e703ec4af8.step8_circum0(ra_action_invoke_5e9e0cecbbfdfa9a2b1306e703ec4af8.java:1032) |
| at com.pegarules.generated.activity.ra_action_invoke_5e9e0cecbbfdfa9a2b1306e703ec4af8.perform(ra_action_invoke_5e9e0cecbbfdfa9a2b1306e703ec4af8.java:189) |
| at com.pegarules.generated.activity.ra_action_updateonetm_06ff20d08ec4dae74a42331d137b2e26.step8_circum0(ra |
| at com.pegarules.generated.activity.ra_action_updateonetm_06ff20d08ec4dae74a42331d137b2e26.step8_circum0(ra_action_updateonetm_06ff20d08ec4dae74a42331d137b2e26.java:793) |
| at com.pegarules.generated.activity.ra_action_updateonetm_06ff20d08ec4dae74a42331d137b2e26.perform(ra_action_updateonetm_06ff20d08ec4dae74a42331d137b2e26.java:207) |
| at com.pegarules.generated.flow.ra_action_sendapprovalrequests_ee03a64974ef02d786747bfe73abd06e.RunTaskActivity(ra_action_sendapprovalrequests_ee03a64974ef02d786747bfe73abd06e.java:4127) |
| at com.pegarules.generated.flow.ra_action_sendapprovalrequests_ee03a64974ef02d786747bfe73abd06e.Task_Utility2_circum0(ra_action_sendapprovalrequests_ee03a64974ef02d786747bfe73abd06e.java:1597) |
| at com.pegarules.generated.flow.ra_action_sendapprovalrequests_ee03a64974ef02d786747bfe73abd06e.perform(ra_action_sendapprovalrequests_ee03a64974ef02d786747bfe73abd06e.java:648) |
| at com.pegarules.generated.flow.ra_action_pxcascadingapproval_5a14afb48bfbd5e1d928e07a92d23640.RestartIssuingFlow(ra_action_pxcascadingapproval_5a14afb48bfbd5e1d928e07a92d23640.java:3833) |
| at com.pegarules.generated.flow.ra_action_pxcascadingapproval_5a14afb48bfbd5e1d928e07a92d23640.perform(ra_action_pxcascadingapproval_5a14afb48bfbd5e1d928e07a92d23640.java:754) |
| at com.pegarules.generated.flow.ra_action_pycascadinggetapproval_34f738e28386fcea19c43d13acc16850.RestartIssuingFlow(ra_action_pycascadinggetapproval_34f738e28386fcea19c43d13acc16850.java:5742) |
| at com.pegarules.generated.flow.ra_action_pycascadinggetapproval_34f738e28386fcea19c43d13acc16850.perform(ra_action_pycascadinggetapproval_34f738e28386fcea19c43d13acc16850.java:767) |
| at com.pegarules.generated.StartFlow_071001_pHqeTXSalkhabVGTYNWp6A.StartFlow07_10_01(StartFlow_071001_pHqeTXSalkhabVGTYNWp6A.java:167) |
| at com.pegarules.generated.StartFlow_071001_pHqeTXSalkhabVGTYNWp6A.invoke(StartFlow_071001_pHqeTXSalkhabVGTYNWp6A.java:76) |
| at com.pega.pegarules.generation.internal.library.LibraryRuntime.resolveAndinvokeFunctionViaReflection(LibraryRuntime.java:133) |
| at com.pega.pegarules.generation.internal.library.LibraryRuntime.invokeLibraryRuntime(LibraryRuntime.java:110) |
| at com.pega.pegarules.session.internal.mgmt.Executable.invokeLibraryRuntime(Executable.java:8786) |
| at com.pega.pegarules.priv.generator.LibrarySupport.resolveAndInvokeFunctionViaReflection(LibrarySupport.java:181) |
| at com.pegarules.generated.pega_procom_flow.StartFlow(pega_procom_flow.java:605) |
| at com.pegarules.generated.activity.ra_action_completeassignment_7c229c203839163ba035bdb1bc564749.step24_circum0(ra_action_completeassignment_7c229c203839163ba035bdb1bc564749.java:2385) |
| at com.pegarules.generated.activity.ra_action_completeassignment_7c229c203839163ba035bdb1bc564749.perform(ra_action_completeassignment_7c229c203839163ba035bdb1bc564749.java:517) |
| at com.pegarules.generated.callActivity_071001_KhcknoEKbSvWlpqH0tlTMw.callActivity07_10_01(callActivity_071001_KhcknoEKbSvWlpqH0tlTMw.java:122) |
| at com.pegarules.generated.callActivity_071001_KhcknoEKbSvWlpqH0tlTMw.invoke(callActivity_071001_KhcknoEKbSvWlpqH0tlTMw.java:82) |
| at com.pegarules.generated.pega_rules_utilities.callActivity(pega_rules_utilities.java:1432) |
| at com.pegarules.generated.activity.ra_action_performflowaction_cc66ac9b214b3cec592f3634031988bc.step18_circum0(ra_action_performflowaction_cc66ac9b214b3cec592f3634031988bc.java:1754) |
| at com.pegarules.generated.activity.ra_action_performflowaction_cc66ac9b214b3cec592f3634031988bc.perform(ra_action_performflowaction_cc66ac9b214b3cec592f3634031988bc.java:382) |
| at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10450) |
| at com.pegarules.generated.activity.ra_action_finishassignment_d0045083e1b45f7e2330fe3464a87513.step10_circum0(ra_action_finishassignment_d0045083e1b45f7e2330fe3464a87513.java:1435) |
| at com.pegarules.generated.activity.ra_action_finishassignment_d0045083e1b45f7e2330fe3464a87513.perform(ra_action_finishassignment_d0045083e1b45f7e2330fe3464a87513.java:229) |
| at com.pegarules.generated.activity.ra_action_approvecr_9c8c596248ae48f833b22a81cf2f55f7.step3_circum0(ra_action_approvecr_9c8c596248ae48f833b22a81cf2f55f7.java:367) |
| at com.pegarules.generated.activity.ra_action_approvecr_9c8c596248ae48f833b22a81cf2f55f7.perform(ra_action_approvecr_9c8c596248ae48f833b22a81cf2f55f7.java:103) |
| at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:641) |
| at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:435) |
| at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3252) |
| at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:384) |
| at sun.reflect.GeneratedMethodAccessor153.invoke(Unknown Source) |
| at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) |
| at java.lang.reflect.Method.invoke(Method.java:606) |
| at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1188) |
| at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:926) |
| at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:811) |
| at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:330) |
| at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:839) |
| at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315) |
| at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263) |
| at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225) |
| at sun.reflect.GeneratedMethodAccessor135.invoke(Unknown Source) |
| at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:338) |
| at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:379) |
| at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:216) |
| at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:238) |
| at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168) |
| at com.pega.pegarules.internal.etier.ejb.EngineBMT_h449u3_ELOImpl.__WL_invoke(Unknown Source) |
| at weblogic.ejb.container.internal.SessionLocalMethodInvoker.invoke(SessionLocalMethodInvoker.java:33) |
| at com.pega.pegarules.internal.etier.ejb.EngineBMT_h449u3_ELOImpl.invokeEngine(Unknown Source) |
| at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278) |
| at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223) |
| at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:485) |
| at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:290) |
| at sun.reflect.GeneratedMethodAccessor151.invoke(Unknown Source) |
| at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:265) |
| at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:118) |
| at javax.servlet.http.HttpServlet.service(HttpServlet.java:751) |
| at javax.servlet.http.HttpServlet.service(HttpServlet.java:844) |
| at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:280) |
| at weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:254) |
| at weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:136) |
| at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:346) |
| at weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:243) |
| at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3432) |
| at weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3402) |
| at weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321) |
| at weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120) |
| at weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:57) |
| at weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2285) |
| at weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2201) |
| at weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2179) |
| at weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1572) |
| at weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:255) |
| at weblogic.work.ExecuteThread.execute(ExecuteThread.java:311) |
| at weblogic.work.ExecuteThread.run(ExecuteThread.java:263) |
| at com.pega.apache.axis2.AxisFault.makeFault(AxisFault.java:430) |
| at com.pega.apache.axis2.transport.TransportUtils.createSOAPMessage(TransportUtils.java:123) |
| at com.pega.apache.axis2.transport.TransportUtils.createSOAPMessage(TransportUtils.java:67) |
| at com.pega.apache.axis2.description.OutInAxisOperationClient.handleResponse(OutInAxisOperation.java:354) |
| at com.pega.apache.axis2.description.OutInAxisOperationClient.send(OutInAxisOperation.java:421) |
| at com.pega.apache.axis2.description.OutInAxisOperationClient.executeImpl(OutInAxisOperation.java:229) |
| at com.pega.apache.axis2.client.OperationClient.execute(OperationClient.java:165) |
| at com.pegarules.generated.activity.ra_action_invokeaxis2_ab4bacc4d22ff691fd98ed821335eb56.step14_circum0(ra_action_invokeaxis2_ab4bacc4d22ff691fd98ed821335eb56.java:3945) |
| at com.pegarules.generated.activity.ra_action_invokeaxis2_ab4bacc4d22ff691fd98ed821335eb56.perform(ra_action_invokeaxis2_ab4bacc4d22ff691fd98ed821335eb56.java:291) |
| at com.pega.apache.axiom.soap.impl.builder.StAXSOAPModelBuilder.constructNode(StAXSOAPModelBuilder.java:299) |
| at com.pega.apache.axiom.soap.impl.builder.StAXSOAPModelBuilder.createOMElement(StAXSOAPModelBuilder.java:246) |
| at com.pega.apache.axiom.soap.impl.builder.StAXSOAPModelBuilder.createNextOMElement(StAXSOAPModelBuilder.java:228) |
| at com.pega.apache.axiom.om.impl.builder.StAXOMBuilder.next(StAXOMBuilder.java:249) |
| at com.pega.apache.axiom.soap.impl.builder.StAXSOAPModelBuilder.getSOAPEnvelope(StAXSOAPModelBuilder.java:198) |
| at com.pega.apache.axiom.soap.impl.builder.StAXSOAPModelBuilder.(StAXSOAPModelBuilder.java:154) |
| at com.pega.apache.axiom.om.impl.common.factory.AbstractOMMetaFactory.internalCreateStAXSOAPModelBuilder(AbstractOMMetaFactory.java:119) |
| at com.pega.apache.axiom.om.impl.common.factory.AbstractOMMetaFactory.createSOAPModelBuilder(AbstractOMMetaFactory.java:129) |
| at com.pega.apache.axiom.om.OMXMLBuilderFactory.createSOAPModelBuilder(OMXMLBuilderFactory.java:426) |
| at com.pega.apache.axiom.om.OMXMLBuilderFactory.createSOAPModelBuilder(OMXMLBuilderFactory.java:405) |
| at com.pega.apache.axis2.builder.SOAPBuilder.processDocument(SOAPBuilder.java:55) |
| at com.pega.apache.axis2.transport.TransportUtils.createDocumentElement(TransportUtils.java:179) |
| at com.pega.apache.axis2.transport.TransportUtils.createSOAPMessage(TransportUtils.java:145) |
| at com.pega.apache.axis2.transport.TransportUtils.createSOAPMessage(TransportUtils.java:108) |
Ericsson
Can I be provided with the error that is responsible for the SOAP Service failed issue.
PEG
Yeah. Entire stacktrace for failure scenario.
Ericsson
Uploaded the entire stack Trace above
PEG
Can you please attach the log file as an attachment to this thread? You can find the attach option in advanced editor.
Verizon
Click on the Step Page of the Connect-SOAP step. You can find the failure reason there. Also, can you check using SOAPUI software to confirm if the service is working fine. So we can narrow down whether there issue is issue in the service itself or not.
Ericsson
First Element must contain the local name, Envelope , but found definitions
This is the message that is set on pySOAPFaultReason
Ericsson
This is the error in parameter page name :
PEG
Hi Abhishek,
Which version of PRPC you are in? Can you please check ws-addressing checkbox is enabled in Advanced tab of Connect-SOAP rule. Please compare the rules in dev and working environment.
It would be better to verify the response in third tools like SOAP UI or tcpmon.
this fails during response processing, please compare the response from dev and prod and compare the differences. Here is an example that an invalid response can cause the similar error: https://community.pega.com/support/support-articles/connect-soap-does-not-handle-response-service
Verizon
It's better to test it using SOAPUI. If there is a problem with the response, check with the team hosting this service for fixing it.
