Atos Syntel
Last activity: 9 Aug 2017 13:05 EDT
How to turn off HTTP compression using DSS or prconfig.xml
Below is the content from help on this
Turn Off HTTP compression
Ordinarily, Pega Platform uses HTTP compression to reduce the length of text messages sent to Internet Explorer. HTTP compression is also used in SOAP messages. This may complicate Tracer debugging, as it is difficult to interpret the messages.
To disable HTTP compression, edit the prconfig.xml file or Dynamic System Setting and adjust the value of the Tracer setting enable-compression setting to "false." This change takes effect the next time your system starts.
Reset this value to enable compression when debugging is complete.
Now my doubt is how to set this in prconfig.xml
<env name="tracer/enable-compression" value="false"/>, Is this correct ?
How to set it in DSS
purpose - tracer/enable-compression (Don't know if this is the correct format)
value - false
owning Ruleset - ?
Hi Dilip,
You can use below setting in prconfig.xml to turn of http compression:
<env name="initialization/httpcompression" value="False" />
Please let me know if this helps.
Vikash
