how stop purge and archive scheduler
I use pega infinity 24.1, I need running the purge and archiving just for one time process, so can please help to implement this.
Please follow the below documentation
Configure Case for Purge and Archival - https://docs.pega.com/bundle/platform/page/platform/system-administration/case-archival-process-setup.html#setting-up-case-archival-con
Retrieving archived Case data - https://docs.pega.com/bundle/platform/page/platform/system-administration/case-archival-data-reviewing.html
@jekryt49 In Pega Infinity 24.1, if you want to run the Purge and Archive process only once and then stop it, you can disable the related schedulers after the first run. First, manually run the purge/archive Job Schedulers like pyPegaArchiver and pyPegaPurger using Admin Studio → Job Scheduler → Actions → Run Now. Once they complete, go to each Job Scheduler and disable them by unchecking the "Enabled" checkbox or setting their "Enable this job scheduler" to false. This ensures the process runs only once and doesn't automatically repeat in future. You can always re-enable them later if needed.
