  SINARMASMSIGLIFE
ID
Last activity: 13 Mar 2017 22:01 EDT
How to Set validation Rule Position
hi,
I have a question according to project requirements , Can I adjust the position of the validation ??
for the example in my case:
i use flowStandard (no screenFlow).
and then , i put validationRule in flow Action :
when i run case type(Case) , validation runs in two positions (header and bottom lines)
hi,
is there anything I missed?
Hello Ryan,
You can set the position of the errors at harness level. Screenshot:
Hope this helps.
Best Regards,
Mounika
  SINARMASMSIGLIFE
ID
hi mounika,
can I find what harness is used ? i check in Live UI , its direct to harness perfom and when I opened it , This seems already locked by pega .
thanks
Hi Ryan,
As Perform is an available rule, you can perform a Save as of that rule to your ruleset and make the changes.
Hope this answers your query.
Best Regards,
Mounika
  SINARMASMSIGLIFE
ID
hi mounika,
can you help me about where can I find the configuration about harness used ?
Is it in Flow ?
or flow action?
and where should I put this new (save as) harness on class path :D ?
I hope you can understand what I want to ask :)
Hello Ryan,
If it is a standard flow you will be able to observe what harness is being called on the assignment shape. For screen flow, on the start shape of the flow.
You can save the harness in the same class hierarchy you are using for the flow.
Best Regards,
Mounika
You can make the form to display the error messages only at the top by modifying the display option of errors in the Harness rule:
  SINARMASMSIGLIFE
ID
hi Haritha_D
thanks for the information , but I want to ask questions as I ask to monika.
please see my reply to monika :D
thanks
  SINARMASMSIGLIFE
ID
hi,
I want to ask about Screen Flow.
can i disable this ? (screenshot)
so the user must press this button  for the next assigment :)
anyone can help me :D
Hello Ryan,
You can try by disabling the "Enable Navigation Link" checkbox in the properties panel. Let us know your observations.
Best Regards,
Mounika
  SINARMASMSIGLIFE
ID
hi mounika,
I've tried the advice given to me.
the result is that when I disable the "Enable Navigation Link" , there is no back button:
when i disable :
when i enable again the "Enable Navigation Link".
so , the user can't go back in screen flow.
hi mounika,
when i disable :
is there any options to handle this link  for validation every assigment without having to jump over.
should I create a separate discussion for this? :D
thanks
  Accenture Australia
Hi Rayn,
For the screen flow tabbed screen flow 7 is the rule used by it. In that as haritha and monika said for the error messages, you can use the display options and for the changing of the harness save as the rule into your rule set and delete all the unwanted things which you donot want.you can see the save as button when you open the rule.
Thank you.
  SINARMASMSIGLIFE
ID
hi,
I have found other solutions for "Navigation Link",
I check all in the choice assignment,so the link disabled for the next, but enabled for the back
