Cox
Last activity: 17 Jul 2017 16:39 EDT
how to set active tab in tabbed repeat layout, on click of link outside of tabbed layout?
tried in different ways like reload section by passing parameters, looked for Java Script code
But not found any solution for this
***Updated by moderator: Marissa to close post***
Hi - I think this question is meant for the Pega Product Support area so I'm going to move it there.
Amanda
Pegasystems
Can we think of any out-of-box portals or frameworks that do this already, so we can learn from their example how they implement it ?
could you please try with run script [pega.desktop.activateDocument] as onClick event. Value '0' is to activate the very first tab in the repeating grid.
note: the configuration worked for a static tabbed layout & hope it works for a dynamic repeating layout too.
Please share your thoughts/observations, Thank you!
psahukaru
Cox
thanks for your response, but it is not working in my scenario.
please find screen shot with the description,
onclick of open i am able to add the tab, but not able to set it as active tab.
the active tab will the previous active tab only.
onclick of open icon on above screen, it has to activate the corresponding tab.
could you please try passing the added tab value dynamically? [pxListSubscript is used for storing the index of a page in a pagelist]...
bitsinglass
>>> Is it possible to identify active tab here
sorry Denny. I'm not sure how we can identify active tab.
- the script I learnt [pega.desktop.activateDocument] helps in activating the desired tab
some one from Pega UI team might help us.
TCS
How to switch to different tab in group layout by clicking on link.
I wanted to switch to interaction history tab once i click on Yes link.
Please give me some solution.
Hi Vishakha Kale ,
Looks like you have got assistance with this question on your original thread- How to switch to different tab in group layout by clicking on link. . Request you to continue the interaction in one place for better assistance on the community.
Thanks!
~Vidyaranjan A V | Community Moderator | Pegasystems Inc.
