How to secure the SMA - Weblogic - using Domain ID
We have a requirement to secure the Pega SMA and I found the artcle below from Pega community.
The article above is working fine but it is only meant for IDs locally created in Weblogic.
Our current requirement is to use a domain ID which is centrally manage in the active directory.
I am unable to assign the Group PegaDiagnosticUser under the domain ID that was created.
Thank you
Hi Bryan,
The following post describes that SMA uses PegaDiagnosticUser. Not sure there is any way around that.
https://community.pega.com/support/support-articles/unable-launch-system-management-application
In addition, SMA is removed in the 8.X versions of PRPC:
https://community.pega.com/knowledgebase/articles/improve-system-administration-and-troubleshooting-pega-apis
The new Pega APIs for system management support end-to-end troubleshooting and administrative operations that were available in the System Management Application (SMA), which has been removed from Pega Platform™.
