Infosys Limited
How to run more than one Pega Robotics Runtime
There is a provision to run more than one Pega Robotics runtime to execute automations, i.e. when you use two different studio instances, you can debug/run two different automations at the same time on same desktop and there are no issues, however when I try to use batch file to run deployed solutions (two at the same time) I get an error saying two run times cannot be possible.
My question is, how is it different from what Pega Robotics studio use to run the runtimes?
How can we run two different automations at the same time in two different runtimes on same desktop? Or is there a way you can attach the second automation to the same run time that is running already?
