Anthem
Last activity: 24 Jun 2018 4:47 EDT
How to rename the class by using the class wizard?
I want to rename the class by using the class wizard?
Example:
IJK-AAA-ZZZ-Work to ABCXYZ-AAA-FFF-Work
I want to rename the IJK class with ABCXYZ
I want to rename ZZZ with FFF
Please answer the following questions
What will happen to associated rules like properties, flows, activities etc…?
Does direct and pattern inheritance references the new class name. Will it get effected with rule resolution?
What will happen to the old class IJK-AAA-ZZZ-Work when it is updated with new ABCXYZ-AAA-FFF-Work?
Do I need to take up a backup before I run a wizard?
What will happen to associated rules like properties, flows, activities etc…?-- All rules will be moved to new class
Does direct and pattern inheritance references the new class name. Will it get effected with rule resolution?-- All Class references will be updated.
Note: Class rename works literally same as "Replace All" function in Notepad.
