Zurich North America
Posted: Nov 1, 2015
Last activity: Nov 2, 2015
Last activity: 2 Nov 2015 4:10 EST
How to pre-fill login ID in windows security popup comes after timeout configured in access group?
Hi Ravi,
Have you explored the HTML rule " Web-TimeOut" ? Line number 90 has this " <input readonly id="txtUserID" type="text" name="UserIdentifier" value="<pega:reference name="pxRequestor.pxUserIdentifier" />" size="30" maxlength="128" />"
Also worth checking whether you can use pxSessionTimer in your portal . Check out this help item : https://community.pega.com/sites/default/files/help_v718/procomhelpmain.htm and this SA article : http://community.pega.com/node/65856 for the usage of the pxSessionTimer
