Murex
LB
Last activity: 15 Sep 2017 5:36 EDT
How to open a popup using an activity
I have a delete button in my UI, the button is linked to an activity where it checks if this object can be deleted or no. If it can be deleted, I deletes it instantly, else I want it to open a popup that this object cannot be deleted.
Any help would be much appreciated!
Thank you!
Process 360
On Click of the button Launch a Flow Action..
Updated: 24 Jun 2016 5:02 EDT
PEG
Updated: 24 Jun 2016 5:23 EDT
Murex
LB
Yes but I need to run an activity first, the actvity checks if I can delete the row or not.
If I can delete I want to delete object only
If I cannot I want to display my section
I also have another question: can I pass a parameter to the popup?
PEG
You can call the activity in "Pre-Processing" method of flow action in action tab. Would this work for you?
Murex
LB
no beacuse I have a grid, and there is a button for each row in the grid.
PEG
On click of that button you can use these actions sequentially -> Run Activity -> Local Action(you can use activity in local action itself) -> Delete action
Murex
LB
perfect! but the activity decides whether I will perform the delete action or not. If I put them as u are suggesting, can I make my activity skip the 3rd action (Delete action)?
Process 360
Place 2 sections - one containing the message that it cannot be deleted and the other containing the autosubmit script. Place conditions on these 2 sections by making use of preactivity of flowaction and on post activity of flowaction run delete item logic.
Murex
LB
Thanks! But I am not in a flow action, I am in a normal harrness.
Process 360
SG
Wipro Technologies
You can use below approach,
Step 1: In activity where you are having delete logic, set a flag whether you want to display Pop-up.
Step 2: Call Activity on Click of button
Step 3: Add Local Action with message after activity and in When condition check for Flag(which we initialized in Delete activity)
I hope that will help. Please let me know anything requires clarification.
Pardeep
