How to move Batch Data flow test runs from lower to higher environment?
How to move batch data flow test runs created in lower environments to higher environment? I tried moving instances of 'Pega-DM-DDF-Work' for the runs created but that is not recognized in the higher environment.
I can see the instances in the higher environment but when I try to open the instance from the class, it throws the error 'No run config present'.
Please advise. Thanks!
