How to manually leave a state of case manipulation in Pega's BotAgent without withdrawing the case?
Is there any way to implement a command for Pega's BotAgent to return from a state in which it is operating a case to the state before operating the case, without withdrawing the case?
I understand that the BotAgent has the following two states;
1. State outside the case context: the state before the case was created.
2. State in case context: the state while the case is being manipulated.
when you execute a command that creates a case, the bot agent will change from the out-of-case-context state to the case-context state.
When executing a command set to "cancel", the bot agent would change from the case-context state to the out-of-case-context state, and the case would be withdrawn at the same time.
We would like to change from case-context state to out-of-case-context state as in cancel command, but not withdraw the case. Is there any way to implement a command that would accomplish this?
