CIBC
Last activity: 9 Mar 2017 11:11 EST
How to implement a secure audit trail for Decision rule changes?
I have a decision table will be delegated to the business user to maintenance. one of the requirement is to have an audit track every time when the user change the content of the decision table.(e.g. add more condition, add more result value...). Try to use the security audit for rule change. but got error message when define the declare trigger rule Applied to Rule-Declare-DecisionTable " a declare rule can not apply to another declare rule". any solution on this?
Thanks in advance.
What rule is being used for the trigger? Depending on what is being changed in the decision table (a property) you could use that as the trigger. Generally an audit of any rule change is maintained automatically as to system, time and user name and ID. You could monitor one of those properties.
Bill
