Tata Consultancy Services
UY
Last activity: 6 Feb 2019 12:28 EST
How to hide OOTB tables in Edit report functionality
While click on edit report there are some OOTB tables with columns (Except Work class) displaying in left panel under "Best Bets" & "All Matches" tabs (PFA, image). We have a requirement that, we need to hide these OOTB tables during edit report.Is there any possibility to hide these OOTB tables ?
While this isn't something I've tried personally, you might want to start with the following:
Using the live UI tool to see if the elements you want to hide are their own separate rules/cells. You might be able to override the UI to conditionally hide those elements.
You could trace the load of the "Edit report screen" to see how that data is populated, and see if it can be adjusted to not include those elements.
Hope this helps!
-Kurt
