EY Advisary
JP
Last activity: 4 Feb 2018 20:02 EST
How to get Dyanamic System Settings in Coneect-file
I plan to create flat file in Pega Cloud , and set the destination path in Dynamic System Settings.
But I could not get the path by following method.
Is there any good way to do it?
i dont think you can directly give the dss using @getDataSystemSetting in the connect file.
to use dss value in connect file , you can use global reference syntax i.e using "=datapage.property"
Steps:
1. Create a data page with source as data transform
2. in the data transform set the dss value to a property using @getDataSystemSetting
3. Then use =DataPage.Property in the connect file.
EY Advisary
JP
Sorry,the capture is lost.I will reprint it.
Hi ,
Could you please share us , how exactly have you given the DSS entry ?
Jeevan
Swetha Gali
EY Advisary
JP
Hi Jeevan
It is as attached.
Kindly
Hi ,
Dynamic Systems settings should be used in the following way:
@getDataSystemSetting("Owning Ruleset","Setting Purpose");
which in your case Owning ruleset is Base and Setting pupose is localdirectory.
Please try above syntax.
Thank you.
EY Advisary
JP
Hi ,
Thanks for advice.
But , the result is not good.
I set it like setting.jpeg , and I got a result like trace.jpeg.
Are there any errors in the settings?
Kindly
Could you share the screenshot of your DSS rule?
EY Advisary
JP
Please see attached.
Steps:
EY Advisary
JP
Thanks a lot!
I use @baseclass and success connect-file.
