Update to Cloud 3: Discontinue use of Local File System
We have a question regarding use of local file system. We wanted to remove all areas where local file system is used. As per Pega, we should be searching for 'sync-data' and finding all rules and moving them to repositories instead. We did that already.
We also have few activities which are using PDF fonts (e.g., /usr/local/tomcat/fonts) or some extracts directory (e.g., /usr/local/tomcat/work/dt1/BIXExtracts) which is also using local directory but not using 'sync-data'.
Our question is, do we need to remove those directories also which have /tomcat/ inside but not using 'sync-data' ?
