how to get access to Constellation
Client wants to get access to Constellation. They are asking how they request the software be installed in one of their Pega Cloud environments.
@kindw U must Install Docker, further pull the docker image, once the docker image is successfully pulled, start the service & further u also need SSL. Refer these..! https://documents.constellation.pega.io/static/88/constellation-appstatic-service-docker.html
https://support.pega.com/discussion/setting-pega-cosmos-react-ui-pega-personal-edition-86
https://thesecmaster.com/procedure-to-install-openssl-on-the-windows-platform/
https://slproweb.com/products/Win32OpenSSL.html
https://docs-previous.pega.com/user-experience/85/installing-cosmos-react-ui-using-docker?
