Asurion
Last activity: 17 Jul 2017 16:30 EDT
How to find the class in pr jar files
Is there a way to find the classes in pega jar files for example prpoi-3.6.jar , If I search the PR_EngineClasses table I can find these classes. I believe this jar contains the Apache POI api classes , but I'm not able to use the classes in POI api directly. does any one knows how to find the classes and methods in these pega jars , so that we can make use of it.
***Updated by moderator: Marissa to close post***
A Vipin mentions the pzPackage column in PR_ENGINECLASSES should give you the information you are looking for.
Example:
SELECT pzpackage, pzclass, pzjar from pr_engineclasses
WHERE pzclass = 'HSSFWorkbook.class';
Result:
PZPACKAGE
com/pega/apache/poi/hssf/usermodel
PZCLASS
HSSFWorkbook.class
PZJAR
prpoi-3.6.jar
You can use the Advanced -> ETier Runtime Environment feature in SMA to perform a Java class lookup to verify the location of a particular class and help confirm you are using what you want / expect.
Example:
The result of the lookup will be displayed in the bottom half of the screen showing the location of the given class name:
If the class cannot be found the Location will not be given as per the example below:
Example:
Result:
PZPACKAGE
PZCLASS
HSSFWorkbook.class
PZJAR
prpoi-3.6.jar
Example:
This can be a useful tool when investigating or reviewing class loading or class not found issues.
