Wipro
Last activity: 9 Sep 2015 9:16 EDT
How does the authentication process work in Pega after a user logs in?
Can any body help me in understanding in details how authentication is done in PEGA after I give my credentials in login screen? Which are the rules being used and can be customized ?
Message was edited by: Kip Jackson Simplified the Discussion Title
Likes (1)
Rahul U -
Hi Jyoti,
What is your exact use case? For example are you trying to setup SSO or customize login screen etc.
Adi
Wipro
Yes I want to customize the login with SSO enabled URL.
The following PDN article should help you customize login screen:
https://pdn.pega.com/user-interface/customizing-the-pega-7-login-screen
I believe above article explains about customizing the login screen UI.
Go through below document.
https://pdn.pega.com/documents/authentication-in-pegarules-process-commander-v53
Though it's bit old but will give you good idea of what you are looking for.
Let us know if this helps.
Wipro
Thanks. It would have been helpful if you can provide any article on authentication. That made the basics clear.
Hope this helps
Hi Jyoti,
What version of Pega are you on? If you are on Pega 7, we support SAML for SSO OOB.
https://pdn.pega.com/integration/web-single-sign-on-sso-with-saml-20
https://pdn.pega.com/integration/configuring-the-pega-7-platform-as-a-service-provider-sp
-Adi
