How does the Accessibility Inspector work?
I am curious as to how Pega knows the sections that are violating accessibility rules. For example, it is able to detect that some properties on the screen may be missing a header, or Pega can tell if you need to add a helper text. Is there a way to see the code that Pega uses? Another link I found said that the Accessibility tool uses the same Javascript API as Live UI. Is there a way to see that Javascript API that is being used?
