Foray Software Pvt Ltd
Posted: May 17, 2017
Last activity: May 17, 2017
Last activity: 17 May 2017 13:35 EDT
how to display captcha in UI(section)
How captcha should be created when we run the section?
Captcha is a security feature mostly used for a login screen. Are you trying to add this to Pega Login screen? If so, then you may just go to Syetem->Settings->Security Policies. There you enable security policy and you may add a captcha from there. But here you are trying to add a captcha in a section. First thing is why that is required? If required then you might try to use a non auto-generated section. There you might try to add 2 HTML fragments named pyCustomCaptchaHead and pyCustomCaptchaBody. To include them you might add the below code
<pega:include name="pyCustomCaptchaHead" type="Rule-HTML-Fragment"/>
<pega:include name="pyCustomCaptchaBody" type="Rule-HTML-Fragment"/>
