How to customize the menu in Pega?
Hi all,
I would like to customize the menu as attached please.
Can you please help me with this?
Regards
Hasnaa
Hi all,
Regards
Hasnaa
Using Live UI check which navigation rule is used to show that menu and customize it. Please reply to this if you need further information.
Thank you for the reply.
Actually the screen attached above is not developped by PEGA, it is a design that i have to respect and develop it using PEGA.
Regards
On the action set of the down arrow, configure "on click" event and action as the "Menu", In the parameters, Context as navigation rule which has a logoff option, Format as "Header Menu". By following the above steps, you will be able to show the menu similar to the attached screen.
Oh ok, yes this is very easy to setup in Pega. Adding button with a click event to launch a nav menu will get you the functionality you are seeking. However, if you are seeking that exact styling, then that will likely require some custom CSS or custom images to make the look and feel consistent with your example.
thank you,
1- However, can you help me to delete this native PEGA arrow (attached in the file).
Regards
Hasnaa
thank you,
Regards
Hasnaa
