Incessant Technologies
Last activity: 9 Jan 2025 10:08 EST
How to create IH Summary Dataset with source as stream dataset
We are moving our entire IH DB data to File repository, upon reading the pdn articles found that when we enable exporting to repository, IH data will start pushing in to pxResponsesStream and from there it will push to repository through data flow.
However our issues are. we want to migrate existing IH table data.
1) If we manually prepare the JSON structure files and push in to file repository, will that work when we run IH summaries.
2) When trying to IH Summary dataset, not able to give source as pxResponsesStream. Not sure why its not showing in dropdown. we need to use pxResponsesStream only to make use of File Repositories right.
3) Does IH summaries calculate on pxReponsesStream dataset only, if yes, how does this dataset retrieves data from file repository.
Struck in proceeding further. Can someone help if you have idea on how exactly file repository things works.
Note :- We are working on Pega Infinity 23
