How to configure custom CSS in Pega skin rule?
Hi @Satya K,
This is the AI generated answer, I have customized
Here are the step-by-step configuration steps to add custom CSS in a Pega Skin rule:
Launch Dev Studio.
Go to Records → User Interface → Skin. or Application -> skin
Open your application’s skin rule (e.g., SmartDisputeSkin, BankAppSkin).
Inside the Skin rule, click on the tab labeled "Included styles".
This section is for adding inline custom CSS.
Under the Additional style sheets add the new css file. label name, webwb, file format css
Paste your custom CSS code into the text area.
Example:
Hi @Satya K,
Launch Dev Studio.
Example:
/* Custom header style for dispute case views */
.dispute-header {
background-color: #002b45;
color: #ffffff;
padding: 12px;
font-size: 18px;
font-weight: bold;
border-bottom: 2px solid #0099cc;
/* Custom primary button */
.btn-dispute-primary {
background-color: #0070d2;
color: white;
border: none;
border-radius: 4px;
padding: 8px 16px;
font-weight: 600;
.btn-dispute-primary:hover {
background-color: #005bb5;
/* Styling for alert messages */
.alert-warning {
background-color: #fff3cd;
color: #856404;
border-left: 5px solid #ffeeba;
padding: 10px;
margin-bottom: 10px;
Click Save.
Check in if your application is in a version-controlled environment.
Open the Section rule where you want to apply styles.
Select the layout or control (e.g., Dynamic Layout, Button).
Go to the Presentation tab.
In the "Custom CSS class" field, enter the class name you defined in your CSS.
Example: custom-header, custom-btn-primary.
Launch the user portal or the section preview.
Verify that the custom styles are applied.
If not visible, clear browser cache or use Live UI → Refresh Section.
If you prefer to manage CSS separately:
Create a Text File rule:
Records → Technical → Text File
Add your CSS there.
In the Skin rule → Included styles tab, add your Text File rule.
I hope it works,
Thank you
