TATA CONSULTANCY SERVICES
Last activity: 17 Jul 2017 16:25 EDT
How to compare Application Versions ?
Today encountered a Production issue & had to compare the Current Application Version with the Previous Application Version. (basically need to compare all the Application Rulesets which are included in each of the current application version with the previous ones to identify the faulty RuleSetVersions which the Project team included in the application).
Our Application is built on 5 different applications above the PegaCardCPM Application. So, I have to compare these 5 applications - current version with the previous version.
Anyone of you came across such situation where you have to compare the application versions ? If so, is there any way to compare them ? What I generally do is... commpare one - to - one manually.
Please share ur thoughts/comments...
Hari
***Updated by moderator: Marissa to close post***
