How to change Location of Log files of File publisher
Hey,
Can someone help me to configure my runtime to generate log file in my preferred location rather than appdata folder?
Hey,
You can refer the below discussion. Changing prlogging.xml or prlog4j2.xml should be helpful
https://collaborate.pega.com/question/72-how-change-pegaruleslog-out-put-directory
Thank You
Kindly check the below links with similar discussion:-
https://collaborate.pega.com/question/saving-log-file-another-locationfile
https://community1.pega.com/community/pega-product-support/question/change-log-location-path
Hari
Hi -
Do you know how to change the location for Log4Net runtime logs from Pega Robotics?
Hello Diane,
kindly follow the below steps to change the location of runtime logs
- Open you appdata folder and find the Runtimeconfig.xml file
- find the publisher for runtimelog4net.txt
-Change the mode to on
- Change the path to your required path.
-Kindly check the below screen shot for your reference.
Hope this helps.
Hari
