How to change "Chart" control labels font size?
We have a requirement to show Doughnut Pie charts on the Pega Dashboard. The chart needs to be drill down enabled. We used "Chart" control instead of "pxChart" control, since the later doesn't allow drill down on click. We need to have similar charts for multiple case types. Instead of using Report Widget, we tried to reuse the same custom Widget for multiple Casetypes by passing Case Type as Parameters from Dashboard Widgets Options screen. However, there is a limitaion of using the "Chart" control. The default font size of labels in the "Chart" control is 10px and we are not able to change it, and the font is too small compared to other Widgets. Is it possible to change the font size?
Hi, we have the same requirement of increasing the font-size as 10px it is too small. It used to be possible in earlier versions to customize the font-size through the chart configuration. I can no longer see it on v8.3...
If anyone has any suggestion on this, I would also be interested.
Thanks.
