Last activity: 22 Jul 2018 14:07 EDT
How Can we setup SMA configuration in PRPC v7.4 Personal Edition
How Can I setup SMA configuration in PRPC v7.4 Personal Edition
PL
Unfortunately, we do not have information clearly saying this.
But as you noticed in the PRPC 7.4 by default the prsysmgmt.war is not deployed. Moreover, in 7.4 we introduce the flag like isPegaCloud in case of cloud env will not display this URL, and this has been introduced in HFix-44169.
Of course, you can rise an media request and provide the business justification and ask for the prsysmgmt.war as well. But, in PRPC7.4 we are strongly recommended to use Designer Studio instead of SMA. And as I said in case of any bugs in SMA, we will not provide a fix as we did before.
That's why I would like to also encourage you to use start using the Designer Studio. As we are going to drop the support for SMA.
Lukasz
Swedbank AB
SE
Hello Raj,
Do you have the required media(prsysmgmt.war) for deploying SMA bundled with the Personal Edition?
If not, then you can request the same using MySupportPortal.
Let us know if this helps!
Thank you,
Pawan
Hi Pawan,
I do not have any war files, I just downloaded 7.4 zar file, extracted it and installed. Nothing else I have done. Currently I'm facing issue with the My support portal. Can I get it in any other way and also tell me how can I deploy war file to server. Please explain in detail. Thanks.
PL
The SMA since 7.4 is deprecated. And all functionality has been moved to the DesigerStudio. Please go Designer Studio -> System -> Operations and you will find the all functionality from SMA.
Please bear in mind that even if you will get a war file, and there will be some bug, we will not gonna fix them.
Lukasz
Could find all the operations through Designer Studio -> System -> Operations but as per the v7.4 Help, we can still access the operations through SMA for each node.
PRPC v7.4 Help: https://community.pega.com/sites/default/files/help_v74/procomhelpmain.htm#tools/systemmanagement/systemmanagement.htm
So, Are you sure that SMA is deprecated from v7.4 ? If yes, can you please provide the link for the same. So that I can use as reference. Thanks!
PL
Lukasz
Thank you so much Lukaz for the clear Info. This is fair enough. I will use the Designer Studio.
Raj
LTI Mindtree
Thank you
Tata Consultancy Services
Hi
Please find below link
https://community.pega.com/support/support-articles/how-install-and-configure-sma
