Avensys Ltd
SG
Last activity: 25 Feb 2021 7:16 EST
PRPC personal edition 8.5.1 is not starting
I'm getting this error, please help:
2021-02-25 11:01:14,855 [StreamServer.Default] [ STANDARD] [ ] [ ] ( dsm.kafka.Kafka) ERROR - Failed to start Kafka on 1 attempt, kafka log ERROR StatusLogger Unable to access file:/C:/PRPCPersonalEdition/tomcat/kafka- Proprietary information hidden/bin/file:C:/PRPCPersonalEdition/tomcat/kafka- Proprietary information hidden/config/log4j2.xml java.io.FileNotFoundException: C:\PRPCPersonalEdition\tomcat\kafka- Proprietary information hidden\bin\file:C:\PRPCPersonalEdition\tomcat\kafka- Proprietary information hidden\config\log4j2.xml (The filename, directory name, or volume label syntax is incorrect) at java.io.FileInputStream.open0(Native Method) at java.io.FileInputStream.open(FileInputStream.java:195) at java.io.FileInputStream.<init>(FileInputStream.java:138) at java.io.FileInputStream.<init>(FileInputStream.java:93) at sun.net.www.protocol.file.FileURLConnection.connect(FileURLConnection.java:90) at sun.net.www.protocol.file.FileURLConnection.getInputStream(FileURLConnection.java:188) at java.net.URL.openStream(URL.java:1045) at org.apache.logging.log4j.core.config.ConfigurationSource.fromUri(ConfigurationSource.java:247) at org.apache.logging.log4j.core.config.ConfigurationFactory$Factory.getConfiguration(ConfigurationFactory.java:404) at org.apache.logging.log4j.core.config.ConfigurationFactory$Factory.getConfiguration(ConfigurationFactory.java:346) at org.apache.logging.log4j.core.config.ConfigurationFactory.getConfiguration(ConfigurationFactory.java:260) at org.apache.logging.log4j.core.LoggerContext.reconfigure(LoggerContext.java:615) at org.apache.logging.log4j.core.LoggerContext.reconfigure(LoggerContext.java:636)
at org.apache.logging.log4j.core.LoggerContext.start(LoggerContext.java:231) at org.apache.logging.log4j.core.impl.Log4jContextFactory.getContext(Log4jContextFactory.java:153) at org.apache.logging.log4j.core.impl.Log4jContextFactory.getContext(Log4jContextFactory.java:45) at org.apache.logging.log4j.LogManager.getContext(LogManager.java:194) at org.apache.logging.log4j.spi.AbstractLoggerAdapter.getContext(AbstractLoggerAdapter.java:121) at org.apache.logging.slf4j.Log4jLoggerFactory.getContext(Log4jLoggerFactory.java:43) at org.apache.logging.log4j.spi.AbstractLoggerAdapter.getLogger(AbstractLoggerAdapter.java:46) at org.apache.logging.slf4j.Log4jLoggerFactory.getLogger(Log4jLoggerFactory.java:29) at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:358) at com.typesafe.scalalogging.Logger$.apply(Logger.scala:42) at kafka.utils.Log4jControllerRegistration$.<init>(Logging.scala:25) at kafka.utils.Log4jControllerRegistration$.<clinit>(Logging.scala) at kafka.utils.Logging$class.$init$(Logging.scala:47) at kafka.Kafka$.<init>(Kafka.scala:30) at kafka.Kafka$.<clinit>(Kafka.scala) at kafka.Kafka.main(Kafka.scala)[2021-02-25 10:57:11,660] ERROR Failed to clean up log for df_run_metrics-13 in dir C:\PRPCPersonalEdition\tomcat\kafka-data due to IOException (kafka.server.LogDirFailureChannel)java.nio.file.FileSystemException: C:\PRPCPersonalEdition\tomcat\kafka-data\df_run_metrics-13\00000000000000000000.log.cleaned -> C:\PRPCPersonalEdition\tomcat\kafka-data\df_run_metrics-13\00000000000000000000.log.swap: The process cannot access the file because it is being used by another process.
at sun.nio.fs.WindowsException.translateToIOException(WindowsException.java:86) ~[?:1.8.0_121] at sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:97) ~[?:1.8.0_121] at sun.nio.fs.WindowsFileCopy.move(WindowsFileCopy.java:387) ~[?:1.8.0_121] at sun.nio.fs.WindowsFileSystemProvider.move(WindowsFileSystemProvider.java:287) ~[?:1.8.0_121] at java.nio.file.Files.move(Files.java:1395) ~[?:1.8.0_121] at org.apache.kafka.common.utils.Utils.atomicMoveWithFallback(Utils.java:697) ~[kafka-clients- Proprietary information hidden.jar:?] at org.apache.kafka.common.record.FileRecords.renameTo(FileRecords.java:212) ~[kafka-clients- Proprietary information hidden.jar:?] at kafka.log.LogSegment.changeFileSuffixes(LogSegment.scala:415) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.Log.replaceSegments(Log.scala:1651) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.Cleaner.cleanSegments(LogCleaner.scala:535) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.Cleaner$$anonfun$doClean$4.apply(LogCleaner.scala:462) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.Cleaner$$anonfun$doClean$4.apply(LogCleaner.scala:461) ~[kafka_2.11- Proprietary information hidden.jar:?] at scala.collection.immutable.List.foreach(List.scala:392) ~[scala-library-2.11.12.jar:?] at kafka.log.Cleaner.doClean(LogCleaner.scala:461) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.Cleaner.clean(LogCleaner.scala:438) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.LogCleaner$CleanerThread.cleanOrSleep(LogCleaner.scala:305) [kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.LogCleaner$CleanerThread.doWork(LogCleaner.scala:291) [kafka_2.11- Proprietary information hidden.jar:?] at kafka.utils.ShutdownableThread.run(ShutdownableThread.scala:82) [kafka_2.11- Proprietary information hidden.jar:?] Suppressed: java.nio.file.FileSystemException: C:\PRPCPersonalEdition\tomcat\kafka-data\df_run_metrics-13\00000000000000000000.log.cleaned -> C:\PRPCPersonalEdition\tomcat\kafka-data\df_run_metrics-13\00000000000000000000.log.swap: The process cannot access the file because it is being used by another process. at sun.nio.fs.WindowsException.translateToIOException(WindowsException.java:86) ~[?:1.8.0_121] at sun.nio.fs.WindowsException.rethrowAsIOException(WindowsException.java:97) ~[?:1.8.0_121] at sun.nio.fs.WindowsFileCopy.move(WindowsFileCopy.java:301) ~[?:1.8.0_121] at sun.nio.fs.WindowsFileSystemProvider.move(WindowsFileSystemProvider.java:287) ~[?:1.8.0_121] at java.nio.file.Files.move(Files.java:1395) ~[?:1.8.0_121] at org.apache.kafka.common.utils.Utils.atomicMoveWithFallback(Utils.java:694) ~[kafka-clients- Proprietary information hidden.jar:?] at org.apache.kafka.common.record.FileRecords.renameTo(FileRecords.java:212) ~[kafka-clients- Proprietary information hidden.jar:?] at kafka.log.LogSegment.changeFileSuffixes(LogSegment.scala:415) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.Log.replaceSegments(Log.scala:1651) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.Cleaner.cleanSegments(LogCleaner.scala:535) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.Cleaner$$anonfun$doClean$4.apply(LogCleaner.scala:462) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.Cleaner$$anonfun$doClean$4.apply(LogCleaner.scala:461) ~[kafka_2.11- Proprietary information hidden.jar:?] at scala.collection.immutable.List.foreach(List.scala:392) ~[scala-library-2.11.12.jar:?] at kafka.log.Cleaner.doClean(LogCleaner.scala:461) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.Cleaner.clean(LogCleaner.scala:438) ~[kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.LogCleaner$CleanerThread.cleanOrSleep(LogCleaner.scala:305) [kafka_2.11- Proprietary information hidden.jar:?] at kafka.log.LogCleaner$CleanerThread.doWork(LogCleaner.scala:291) [kafka_2.11- Proprietary information hidden.jar:?] at kafka.utils.ShutdownableThread.run(ShutdownableThread.scala:82) [kafka_2.11- Proprietary information hidden.jar:?][2021-02-25 10:57:11,685] ERROR Shutdown broker because all log dirs in C:\PRPCPersonalEdition\tomcat\kafka-data have failed (kafka.log.LogManager)
