Santander
BR
Last activity: 6 Oct 2025 14:04 EDT
How to call a DataFlow asynchronously
PEGA 8.8.3
I need a Declare OnChange call to be triggered when the property of the case is filled, which will call an activity, which in turn will call a DataFlow.
Property > Declare OnChange > Activity(DataFlow-Execute) > DataFlow
In my tests, I noticed that the case waits for all DataFlow processing to be completed before releasing the screen to the user. This is bad because the user will wait for the processing to finish, which should be running asynchronously in the background.
As an alternative, I ran the following test: I created a new activity, then Activity 1 of the declare onchange executes Activity 2 using a Call-Async-Activity, and Activity 2 then executes the DataFlow. Apparently, Activity 2 was executed asynchronously and released the case to the user while the dataflow processing continued in the background by another thread.
Property > Declare OnChange > Activity 1(Call-Async-Activity) > Activity 2(DataFlow-Execute) > DataFlow
However, checking the https://docs.pega.com/bundle/platform-88/page/platform/reference/method… documentation, the recommendation is to change the activity type to "Asynchronous." When I do this, I get an error when saving: Method—Activity of type 'ASYNCHRONOUS' cannot use method 'DataFlow-Execute,' so I kept the activity type = Activity.
PEGA 8.8.3
I need to know if I can use Call-Async-Activity to call an activity with Activity type = Activity, or if you recommend another solution to call the Dataflow asynchronously so that its processing doesn't impact the user's screen.
