Declarative rules are not called as part of Real time dataflow
Declarative rules are not called as part of Real time dataflow.
Steps to replicate:
- Create Real time data flow with source as Data Set fetching records through Kafka topic.
- As an output of data flow, create new case
- Preconfigure Declare Trigger or Declare on change rule in new case context
- Push new record on topic
Expected –
New case should be created
Declare Trigger/Declare on changes rule should be called
Actual –
New case is created but declarative rules are not called
Does anyone faced similar issue? I tried with different setting for declarative rules.
***Edited by Moderator: Pooja Gadige to add capability tags***
@raghu44 @SandeepM0807 @PraveenN2908
Here was the outcome of the investigation:
Solution description:
Declarative engine is disabled within dataflow processing.
Hence even forcing to use the platform clipboard page have no impact.
We were given confirmation from our Decisioning product management that declarative engine is disabled within dataflow processing,
Please revert the DSS as it wouldnt be helpful anyways.
I am afraid it is not possible to trigger any declaratives from within the Dataflow execution.
https://community.pega.com/support/support-articles/declarative-rules-are-not-triggered-running-real-time-events
