How to avoid performance degrade when PRPushServlet feature is enabled ?
When Performance degrades on using PRPushServlet and if the push feature is not required for the application , we are aware that we can disable the push servlet features by doing the below configuration change.
Disable the Push feature by setting the following Dynamic System Setting:
Owning Ruleset: Pega-Engine
Purpose: prconfig/server-push/enabled/default
value: false
But eventually what is the solution to avoid the performance degrade when we enable the PRPushServlet feature for the given application? Any recommendation or best practices ?
Any thoughts or inputs on this ?
Thanks in advance.
