IBM
CN
Last activity: 21 Aug 2017 15:30 EDT
How to automate closing a javascript popup message dialog
I met such an issue that:I'm using OpenSpan Proprietary information hidden, today i failed to automate submitting a form because i can't close a javascript popup message dialog with validation information based on a web application.
<input type="button" onclick="Set()" id="totoro"/>
The normal process is that once i click this button,the function "Set()" will validate data in this form,if passed,the form will be submitted;otherwise it will popup a message dialog.
Now I interrogated this button and "Ok" button of popup message dialog,I found a very strange issue that the performclick method of button "totoro" must wait the popup window to close itself. It means I can't automate closing popup window. Meanwhile I also tried to use invokescript,but it didn't work.
Any help is appreciated.
The dialogue box causes the current thread to lock until the dialogue box is dismissed. You will have to use the WaitForEvent() method in order to spin off a new thread to PerformClick on the OK button.
Ref: http://help.openspan.com/80/Adapters_Interrogation/Wait_For_Event_.htm
