Barclays
How to add default value in column while uploading data in data table
Hi have requirement where I have created on Data table in Pega. I will be adding records in data table and process it later using agent. I am going to upload CSV file directly using OOTB import icon. But to identify each record I need to store the upload ID in one column. This upload ID is created by Pega for each csv upload. I don't want to loop complete file since it may have 10K+ records. I checked pyPreImportBatchProcessing activity, but it gets called only once not for each record.
***Edited by Moderator: Pallavi to update platform capability tags, move from Pega Academy to Product***
Are you looking for a way to add default value while uploading/importing records into a DataType?
What version of Pega are you using? Could you elaborate your requirement?
