LTI
Last activity: 3 Jul 2024 10:15 EDT
HFIX-B188 API Calls failing with a bad request
Hi Team ,
As a part of critical hotfix deployment we are planning to deploy HFIX-B188 in Production environment . Kindly check and let us know will this leads to any API related failures as such as user raising concern for the same ?
Sharath D
Proprietary information hidden
@SharathD16664488 - Critical hotfixes are safe and secure to add and will be proactively shared to client to overcome any production down or blocker situation.
This hotfix is given when API calls are failing with Service Exception -Required parameter, Incorrect value for context name.
In alerts the issue is related to the property pyMinHCVersionIOS and in this property ruleform checkbox "Allow use as reference property in activities" is enabled. To overcome this issue this hotfix is been provided.
Thank you.
