ASM
ID
Last activity: 29 Dec 2025 10:27 EST
[Help] Pega Mobile login fails after forgot password until app is closed
I am facing an issue only on Pega Mobile 8.3 and 24.1 related to the Forgot Password / Reset Password flow.
Scenario
User selects Forgot Password
OTP validation succeeds
Password is successfully changed
User is redirected back to the login screen
User attempts to log in using the new password
Issue
When the user tries to log in again using the new password, the login does not succeed.
The screen simply refreshes and returns to the login page.
In order to log in successfully, the user must close the mobile application completely and reopen it, then log in again using the new password.
In some cases, the following error is also displayed:
"Application misconfigured. The state parameter does not match the expected value."
This issue does not occur on the web version, only on Pega Mobile.
Is there any recommended or supported solution to allow the user to log in immediately after resetting the password on Pega Mobile, without requiring the user to close and reopen the application?
Scenario
Issue
Any guidance or best practice would be greatly appreciated.
Thank you.
