Fifth Third Bank Bank
Last activity: 12 Jul 2017 9:11 EDT
help needed on developing Workflow to loop tghrough the records of a txt file
I have a requirement to load a .txt file of account numbers to Openspan and then perform a desktop automation flow(navigate through various web portal screens). Any help of how to load the .txt file and read through each account in the file would be appreciated, an example would be much better! At this time I can't use the excel file as the office connectors are not installed on my machine.
Srini
Finally it's working as I expected. The learning is that I can't use Execute (Entry/Exit points) component when the automation is NOT invoking from other automation. Now I have changed Execute with Started and supplied the filename path via a local variable. Thanks Sasnt for your support. Finally below is the flow I came up to load loop through the txt file of records.
