    Coforge
Last activity: 22 Jan 2025 16:39 EST
Getting Failure Opening the Rule instance even after redeploying the rule
In dev environment I moved the rules to higher version but did not update the class version. When code is promoted to higher environment got error while invoking connector in Datapage- " You lack access to execute Rule-Obj- Activity pxcallconnector" while tracing. I redeployed the code after updating class version. Even after redeployment getting the same error while opening the rules and also unable to delete these rules manually or using delete wizard. Also tried recreating the classes and rules and redeployed but still the same issue.
