Last activity: 27 Jun 2016 7:33 EDT
Getting exception while configuring jconsole for Tomcat
Trying to enable JMX for Tomcat service. Did all the configuration according to this (https://mesh.pega.com/docs/DOC-94701 ) document. But getting below exception after configuring SMA and trying to click the node.
MSG:
com.pega.jmx.ui.util.JMXClientException: Cannot connect to the server with specified settings
Failed to retrieve RMIServer stub: javax.naming.ServiceUnavailableException [Root exception is java.rmi.ConnectException: Connection refused to host: localhost; nested exception is: java.net.ConnectException: Connection refused: connect]
Stack Trace:
MSG:
Stack Trace:
Failed to retrieve RMIServer stub: javax.naming.ServiceUnavailableException [Root exception is java.rmi.ConnectException: Connection refused to host: localhost; nested exception is: java.net.ConnectException: Connection refused: connect] at com.pega.jmx.ui.util.JMXClientException.wrap(JMXClientException.java:49) at com.pega.jmx.ui.action.AuthenticateAction.execute(AuthenticateAction.java:346) at com.pega.jmx.ui.action.AuthenticateAction.executeWithoutValidation(AuthenticateAction.java:86) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at com.opensymphony.xwork2.DefaultActionInvocation.invokeAction(DefaultActionInvocation.java:450) at com.opensymphony.xwork2.DefaultActionInvocation.invokeActionOnly(DefaultActionInvocation.java:289) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:252) at org.apache.struts2.interceptor.DeprecationInterceptor.intercept(DeprecationInterceptor.java:41) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at org.apache.struts2.interceptor.debugging.DebuggingInterceptor.intercept(DebuggingInterceptor.java:256) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at com.opensymphony.xwork2.interceptor.DefaultWorkflowInterceptor.doIntercept(DefaultWorkflowInterceptor.java:167) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:98) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:100) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at com.opensymphony.xwork2.interceptor.ConversionErrorInterceptor.intercept(ConversionErrorInterceptor.java:138) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at com.opensymphony.xwork2.interceptor.ParametersInterceptor.doIntercept(ParametersInterceptor.java:254) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:98) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at com.opensymphony.xwork2.interceptor.ParametersInterceptor.doIntercept(ParametersInterceptor.java:254) at com.opensymphony.xwork2.interceptor.MethodFilterInterceptor.intercept(MethodFilterInterceptor.java:98) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at com.opensymphony.xwork2.interceptor.StaticParametersInterceptor.intercept(StaticParametersInterceptor.java:191) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at org.apache.struts2.interceptor.MultiselectInterceptor.intercept(MultiselectInterceptor.java:73) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at org.apache.struts2.interceptor.CheckboxInterceptor.intercept(CheckboxInterceptor.java:91) at com.opensymphony.xwork2.DefaultActionInvocation.invoke(DefaultActionInvocation.java:246) at org.apache.struts2.interceptor.FileUploadInterceptor.intercept(FileUploadInterceptor.java:252)
Please do the needful.
