new jersey courts
Last activity: 26 May 2017 12:08 EDT
Getting exception com.pega.pegarules.pub.services.ConnectorException: Caught unhandled exception: java.net.SocketException: Connection reset in Connect-Rest
Hi Team,
I am getting following exception with the connect-rest integration. the same service I can able to hit over http, only with https I am getting the issue. Even I have imported keystore into the pega system(client provided .pfx file, as pega is not supporting the format I have changed this to .jks file using keytool) & created DSS https/allowAllHostnames , & set Value:true as this is not existed in my environment.
I have tried to ping the server from pega application server machine with ping command, even it is able to hit the service physical machine with the service machine name/IP Address.
Can you please suggest on this issue.
Hi Team,
| Exception Trace | com.pega.pegarules.pub.services.ConnectorException: Caught unhandled exception: java.net.SocketException: Connection reset |
| Java Stack Trace | |
| at com.pegarules.generated.activity.ra_action_pyinvokerestconnector_c8e6bb23a4b0e46307cb13a01a31b1ae.step5_circum0(ra_action_pyinvokerestconnector_c8e6bb23a4b0e46307cb13a01a31b1ae.java:1688) | |
| at com.pegarules.generated.activity.ra_action_pyinvokerestconnector_c8e6bb23a4b0e46307cb13a01a31b1ae.perform(ra_action_pyinvokerestconnector_c8e6bb23a4b0e46307cb13a01a31b1ae.java:137) | |
| at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3527) | |
| at com.pegarules.generated.activity.ra_action_invoke_4dc028ab25da14c2d6798b84993f966a.step7_circum0(ra_action_invoke_4dc028ab25da14c2d6798b84993f966a.java:1002) | |
| at com.pegarules.generated.activity.ra_action_invoke_4dc028ab25da14c2d6798b84993f966a.perform(ra_action_invoke_4dc028ab25da14c2d6798b84993f966a.java:172) | |
| at com.pegarules.generated.activity.sh_action_completecase_6f39108f194772370ea22fe0cff1a4c0.step4_circum0(sh_action_completecase_6f39108f194772370ea22fe0cff1a4c0.java:442) | |
| at com.pegarules.generated.activity.sh_action_completecase_6f39108f194772370ea22fe0cff1a4c0.perform(sh_action_completecase_6f39108f194772370ea22fe0cff1a4c0.java:118) | |
| at com.pega.pegarules.session.internal.mgmt.Executable.doAction(Executable.java:3260) | |
| at com.pegarules.generated.activity.ra_action_pyrunrecordexecute_0f739eeb61a9046be9a6d286a73f151a.step1_circum0(ra_action_pyrunrecordexecute_0f739eeb61a9046be9a6d286a73f151a.java:175) | |
| at com.pegarules.generated.activity.ra_action_pyrunrecordexecute_0f739eeb61a9046be9a6d286a73f151a.perform(ra_action_pyrunrecordexecute_0f739eeb61a9046be9a6d286a73f151a.java:69) | |
| at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10674) | |
| at com.pegarules.generated.activity.ra_action_pzrunrecordexecute_f73998920c112079b42c8cca0a4e44ad.step11_circum0(ra_action_pzrunrecordexecute_f73998920c112079b42c8cca0a4e44ad.java:1009) | |
| at com.pegarules.generated.activity.ra_action_pzrunrecordexecute_f73998920c112079b42c8cca0a4e44ad.perform(ra_action_pzrunrecordexecute_f73998920c112079b42c8cca0a4e44ad.java:245) | |
| at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646) | |
| at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:467) | |
| at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3166) | |
| at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:390) | |
| at sun.reflect.GeneratedMethodAccessor83.invoke(Unknown Source) | |
| at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:55) | |
| at java.lang.reflect.Method.invoke(Method.java:508) | |
| at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1301) | |
| at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1038) | |
| at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:893) | |
| at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331) | |
| at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:825) | |
| at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:327) | |
| at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:270) | |
| at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:247) | |
| at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278) | |
| at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223) | |
| at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:594) | |
| at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:390) | |
| at sun.reflect.GeneratedMethodAccessor82.invoke(Unknown Source) | |
| at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370) | |
| at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411) | |
| at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:224) | |
| at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:273) | |
| at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121) | |
| at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doGet(WebStandardBoot.java:92) | |
| at javax.servlet.http.HttpServlet.service(HttpServlet.java:622) | |
| at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) | |
| at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:230) | |
| at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) | |
| at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) | |
| at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) | |
| at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198) | |
| at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96) | |
| at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:474) | |
| at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140) | |
| at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79) | |
| at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:624) | |
| at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87) | |
| at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:349) | |
| at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:783) | |
| at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66) | |
| at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:798) | |
| at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1434) | |
| at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) | |
| at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1153) | |
| at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) | |
| at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) | |
| at java.lang.Thread.run(Thread.java:785) | |
| at java.net.SocketInputStream.read(SocketInputStream.java:220) | |
| at java.net.SocketInputStream.read(SocketInputStream.java:152) | |
| at com.ibm.jsse2.a.a(a.java:79) | |
| at com.ibm.jsse2.a.a(a.java:182) | |
| at com.ibm.jsse2.as.a(as.java:883) | |
| at com.ibm.jsse2.as.a(as.java:382) | |
| at com.ibm.jsse2.e.read(e.java:16) | |
| at com.pega.apache.http.impl.io.AbstractSessionInputBuffer.fillBuffer(AbstractSessionInputBuffer.java:149) | |
| at com.pega.apache.http.impl.io.SocketInputBuffer.fillBuffer(SocketInputBuffer.java:110) | |
| at com.pega.apache.http.impl.io.AbstractSessionInputBuffer.readLine(AbstractSessionInputBuffer.java:264) | |
| at com.pega.apache.http.impl.conn.DefaultResponseParser.parseHead(DefaultResponseParser.java:98) | |
| at com.pega.apache.http.impl.io.AbstractMessageParser.parse(AbstractMessageParser.java:252) | |
| at com.pega.apache.http.impl.AbstractHttpClientConnection.receiveResponseHeader(AbstractHttpClientConnection.java:281) | |
| at com.pega.apache.http.impl.conn.DefaultClientConnection.receiveResponseHeader(DefaultClientConnection.java:247) | |
| at com.pega.apache.http.impl.conn.AbstractClientConnAdapter.receiveResponseHeader(AbstractClientConnAdapter.java:219) | |
| at com.pega.apache.http.protocol.HttpRequestExecutor.doReceiveResponse(HttpRequestExecutor.java:298) | |
| at com.pega.apache.http.protocol.HttpRequestExecutor.execute(HttpRequestExecutor.java:125) | |
| at com.pega.apache.http.impl.client.DefaultRequestDirector.tryExecute(DefaultRequestDirector.java:645) | |
| at com.pega.apache.http.impl.client.DefaultRequestDirector.execute(DefaultRequestDirector.java:464) | |
| at com.pega.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:825) | |
| at com.pega.apache.http.impl.client.AbstractHttpClient.execute(AbstractHttpClient.java:759) | |
at com.pegarules.generated.activity.ra_action_pyinvokerestconnector_c8e6bb23a4b0e46307cb13a01a31b1ae.step5_circum0(ra_action_pyinvokerestconnector_c8e6bb23a4b0e46307cb13a01a31b1ae.java:1286)
Thanks, Rohith |
While reviewing the SR associated with this thread it was discovered that SA-37379 Unable to connect the service from connect-rest over https was created as a resolution. Please refer to this SA if you have the same question.
