State Farm Insurance
Last activity: 23 Sep 2015 12:57 EDT
Getting a classCastException from connect-REST, mapping from a json where there is a pagelist property
Created a connect-REST rule, in PRPC 7.1.7, using the integration wizard that maps the _GET from a Json. In the json opbject, is a property ("staffmember"), that is a page-list. However if only one entry(staffmember) comes thru, I get a classCastExpection. Yet multiple staffmembers under that property/page-list work fine. I've interrogated the json, and its is defined the same if there is one or multiple staffmembers in the object.
Now, originally, PRPC created the "staffmember" property rule as a page. So the connect-Rest would fail on any calls where the json returned more than one staffmember. (a mapping error, i forget now) So, i opened the ruleset, deleted the rule, recreated it as a page-list. Based on this, i'm wondering if there is something in the rules DB that i'm needing to clear or delete. We have deleted exptemp and recycled the server to no avail.
There are other properties created as a page-lists, however I can't be sure if they fail under 1 entry either, as I don't own that data.
PEG
In which format are you passing the request to json? Is it GET/POST request?
PageList we need to send the request as below. Example for POST request input for pagelist property.
[{"staffmember","Test"}]
Please share the stacktrace also.
Updated: 23 Sep 2015 12:57 EDT
know issue with JSON arrays who have single elements. The response coming back has to have been correctly assembled whether the array has multiple elements or not.
Two good links on this :
In the GET request.
This is only part of the entire JSON:
Multiple staff members:
"staffMembers":{"staffMember":[{"alias":"xxxx","caption":"","memberName":"Name LName","title":"Office Representative","license":"10xx","associd":"XBWKAK"},{"alias":"yyyy","caption":"","memberName":"Her Name","title":"","license":"8c0v56","associd":"00"}]}
single staff member:
"staffMembers":{"staffMember":{"alias":"zzzz","caption":"","memberName":"HIs Name","title":"","license":"9b78","associd":"0"}}
Stack Trace:
2015-09-23 09:37:57,975 [ WebContainer : 11] [ STANDARD] [ R21280:01.01] (ector.Rule_Connect_REST.Action) INFO J30K-A4 - Starting remote service invocation...
2015-09-23 09:37:58,022 [ WebContainer : 11] [ STANDARD] [ R21280:01.01] (ector.Rule_Connect_REST.Action) INFO J30K-A4 - Adding outbound header values to HTTP request
2015-09-23 09:37:58,392 [ WebContainer : 11] [ STANDARD] [ R21280:01.01] (ector.Rule_Connect_REST.Action) INFO J30K-A4 - HTTP Status code: 200
2015-09-23 09:37:58,406 [ WebContainer : 11] [ STANDARD] [ R21280:01.01] (ector.Rule_Connect_REST.Action) INFO J30K-A4 - Reading HTTP response message data
2015-09-23 09:38:01,279 [ WebContainer : 11] [ STANDARD] [ R21280:01.01] ( internal.mgmt.Executable) ERROR J30K-A4 - Exception
com.pega.pegarules.pub.services.InboundMappingException: Error mapping incoming response to .response_GET: java.lang.ClassCastException: java.util.LinkedHashMap incompatible with java.util.List
at com.pega.pegarules.integration.engine.internal.util.PRServiceUtils.mapInboundData(PRServiceUtils.java:1267)
at com.pegarules.generated.activity.ra_action_pyinvokerestconnector_eb7dafe6dac00116b03b951c8add1e9a.step12_circum0(ra_action_pyinvokerestconnector_eb7dafe6dac00116b03b951c8add1e9a.java:2815)
Stack Trace:
at com.pegarules.generated.activity.ra_action_pyinvokerestconnector_eb7dafe6dac00116b03b951c8add1e9a.perform(ra_action_pyinvokerestconnector_eb7dafe6dac00116b03b951c8add1e9a.java:260)
at com.pega.pegarules.session.internal.mgmt.Executable.doActivity(Executable.java:3500)
at com.pegarules.generated.activity.ra_action_invoke_6a91441c4f6e5048b63360383ae1b952.step7_circum0(ra_action_invoke_6a91441c4f6e5048b63360383ae1b952.java:1002)
at com.pegarules.generated.activity.ra_action_invoke_6a91441c4f6e5048b63360383ae1b952.perform(ra_action_invoke_6a91441c4f6e5048b63360383ae1b952.java:172)
at com.pegarules.generated.activity.ra_action_performresourcerestconnection_bec425fe7711ebc6b8e22f129b084920.step1_circum0(ra_action_performresourcerestconnection_bec425fe7711ebc6b8e22f129b084920.java:240)
at com.pegarules.generated.activity.ra_action_performresourcerestconnection_bec425fe7711ebc6b8e22f129b084920.perform(ra_action_performresourcerestconnection_bec425fe7711ebc6b8e22f129b084920.java:70)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeActivity(Executable.java:10521)
at com.pegarules.generated.activity.ra_action_invokerestconnection_a0a2ebf65bf77e7e7967348064bb8c1e.step3_circum0(ra_action_invokerestconnection_a0a2ebf65bf77e7e7967348064bb8c1e.java:243)
at com.pegarules.generated.activity.ra_action_invokerestconnection_a0a2ebf65bf77e7e7967348064bb8c1e.perform(ra_action_invokerestconnection_a0a2ebf65bf77e7e7967348064bb8c1e.java:96)
at com.pegarules.generated.activity.ra_action_retrieveagentinfo_9131f4e21e59f8029da7cad0117edcac.step2_circum0(ra_action_retrieveagentinfo_9131f4e21e59f8029da7cad0117edcac.java:205)
at com.pegarules.generated.activity.ra_action_retrieveagentinfo_9131f4e21e59f8029da7cad0117edcac.perform(ra_action_retrieveagentinfo_9131f4e21e59f8029da7cad0117edcac.java:69)
at com.pegarules.generated.activity.ra_action_preprocessingagentinfo_8bee1b26875ffa9b8bf9f10f10a24a26.step1_circum0(ra_action_preprocessingagentinfo_8bee1b26875ffa9b8bf9f10f10a24a26.java:202)
at com.pegarules.generated.activity.ra_action_preprocessingagentinfo_8bee1b26875ffa9b8bf9f10f10a24a26.perform(ra_action_preprocessingagentinfo_8bee1b26875ffa9b8bf9f10f10a24a26.java:69)
at com.pegarules.generated.callActivity_071017_xvj4o_pyNDBZ4Gy293rekg.callActivity07_10_17(callActivity_071017_xvj4o_pyNDBZ4Gy293rekg.java:122)
at com.pegarules.generated.callActivity_071017_xvj4o_pyNDBZ4Gy293rekg.invoke(callActivity_071017_xvj4o_pyNDBZ4Gy293rekg.java:82)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.resolveAndinvokeFunctionViaReflection(LibraryRuntime.java:133)
at com.pega.pegarules.generation.internal.library.LibraryRuntime.invokeLibraryRuntime(LibraryRuntime.java:110)
at com.pega.pegarules.session.internal.mgmt.Executable.invokeLibraryRuntime(Executable.java:8954)
at com.pega.pegarules.priv.generator.LibrarySupport.resolveAndInvokeFunctionViaReflection(LibrarySupport.java:181)
at com.pegarules.generated.pega_rules_utilities.callActivity(pega_rules_utilities.java:1619)
at com.pegarules.generated.flowaction.ra_action_agentinfoview_9aaa9ec9221251a4889d574970b486f0.RunFlowActionActivity_circum0(ra_action_agentinfoview_9aaa9ec9221251a4889d574970b486f0.java:323)
at com.pegarules.generated.flowaction.ra_action_agentinfoview_9aaa9ec9221251a4889d574970b486f0.perform(ra_action_agentinfoview_9aaa9ec9221251a4889d574970b486f0.java:72)
at com.pega.pegarules.session.internal.mgmt.Executable.doAction(Executable.java:3305)
at com.pegarules.generated.activity.ra_action_runflowactionactivity_58efc1b6f854c94714f657cadaebe7ff.step3_circum0(ra_action_runflowactionactivity_58efc1b6f854c94714f657cadaebe7ff.java:383)
at com.pegarules.generated.activity.ra_action_runflowactionactivity_58efc1b6f854c94714f657cadaebe7ff.perform(ra_action_runflowactionactivity_58efc1b6f854c94714f657cadaebe7ff.java:103)
at com.pegarules.generated.activity.ra_action_performpreprocessing_09a325f67bf9b651644b077408ec0712.step10_circum0(ra_action_performpreprocessing_09a325f67bf9b651644b077408ec0712.java:925)
at com.pegarules.generated.activity.ra_action_performpreprocessing_09a325f67bf9b651644b077408ec0712.perform(ra_action_performpreprocessing_09a325f67bf9b651644b077408ec0712.java:244)
at com.pegarules.generated.html_section.ra_stream_sfflowactionhtml_simple_0f52d88b1335b4eb179ff9d678e56b74.execute(ra_stream_sfflowactionhtml_simple_0f52d88b1335b4eb179ff9d678e56b74.java:117)
at com.pega.pegarules.session.internal.mgmt.StreamBuilderTools.appendStreamKeepProperties(StreamBuilderTools.java:717)
at com.pega.pegarules.session.internal.mgmt.autostreams.IncludeStreamRuntime.getStream(IncludeStreamRuntime.java:332)
at com.pega.pegarules.session.internal.mgmt.autostreams.IncludeStreamRuntime.emitIncludeStreamReference(IncludeStreamRuntime.java:252)
at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuntimeImpl.emitIncludeStreamReference(AutoStreamRuntimeImpl.java:358)
at com.pegarules.generated.html_section.ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.sectionBodyIncludeInCell_1(ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.java:262)
at com.pegarules.generated.html_section.ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.sectionIncludeInCell_SFFlowActionHTML_Simple_1(ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.java:236)
at com.pegarules.generated.html_section.ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.layoutBody_1(ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.java:383)
at com.pegarules.generated.html_section.ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.pzLayoutBodyWrapper_1(ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.java:225)
at com.pegarules.generated.html_section.ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.pzLayout_1(ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.java:390)
at com.pegarules.generated.html_section.ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.pzSectionBody_1(ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.java:212)
at com.pegarules.generated.html_section.ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.execute(ra_stream_navigationframework_60c7990b17184a0ade12237946d23f6a.java:100)
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:4033)
at com.pega.pegarules.session.internal.mgmt.autostreams.AutoStreamRuleRuntime.getSectionStream(AutoStreamRuleRuntime.java:149)
at com.pegarules.generated.html_harness.ra_stream_treenavigation_9d1846d42810e28f13c9fe5867d9a0b2.includeSectionBody_3(ra_stream_treenavigation_9d1846d42810e28f13c9fe5867d9a0b2.java:3600)
at com.pegarules.generated.html_harness.ra_stream_treenavigation_9d1846d42810e28f13c9fe5867d9a0b2.generatePegaHarnessDiv_6(ra_stream_treenavigation_9d1846d42810e28f13c9fe5867d9a0b2.java:1782)
at com.pegarules.generated.html_harness.ra_stream_treenavigation_9d1846d42810e28f13c9fe5867d9a0b2.execute(ra_stream_treenavigation_9d1846d42810e28f13c9fe5867d9a0b2.java:676)
at com.pega.pegarules.session.internal.mgmt.Executable.getStream(Executable.java:3861)
at com.pegarules.generated.activity.ra_action_show_harness_3a715fceb3725b54f857d8327a1c5bba.step6_circum0(ra_action_show_harness_3a715fceb3725b54f857d8327a1c5bba.java:684)
at com.pegarules.generated.activity.ra_action_show_harness_3a715fceb3725b54f857d8327a1c5bba.perform(ra_action_show_harness_3a715fceb3725b54f857d8327a1c5bba.java:155)
at com.pegarules.generated.activity.ra_action_displayharness_1d414472711606645476be6f8133a69a.step2_circum0(ra_action_displayharness_1d414472711606645476be6f8133a69a.java:336)
at com.pegarules.generated.activity.ra_action_displayharness_1d414472711606645476be6f8133a69a.perform(ra_action_displayharness_1d414472711606645476be6f8133a69a.java:86)
at com.pegarules.generated.activity.ra_action_perform_b0b86ee90d82814cd7e3e5124876b4e1.step16_circum0(ra_action_perform_b0b86ee90d82814cd7e3e5124876b4e1.java:1211)
at com.pegarules.generated.activity.ra_action_perform_b0b86ee90d82814cd7e3e5124876b4e1.perform(ra_action_perform_b0b86ee90d82814cd7e3e5124876b4e1.java:352)
at com.pegarules.generated.activity.ra_action_gotoprevioustask_9fae697ae221236e1c8151e5eed4a8c1.step18_circum0(ra_action_gotoprevioustask_9fae697ae221236e1c8151e5eed4a8c1.java:1768)
at com.pegarules.generated.activity.ra_action_gotoprevioustask_9fae697ae221236e1c8151e5eed4a8c1.perform(ra_action_gotoprevioustask_9fae697ae221236e1c8151e5eed4a8c1.java:374)
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.runActivitiesAlt(ThreadRunner.java:646)
at com.pega.pegarules.session.internal.mgmt.PRThreadImpl.runActivitiesAlt(PRThreadImpl.java:461)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.runActivities(HttpAPI.java:3322)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:385)
at sun.reflect.GeneratedMethodAccessor179.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:56)
at java.lang.reflect.Method.invoke(Method.java:620)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1270)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:841)
at com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331)
at com.pega.pegarules.session.internal.engineinterface.service.HttpAPI.invoke(HttpAPI.java:850)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
at com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java)
at sun.reflect.GeneratedMethodAccessor119.invoke(Unknown Source)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:245)
at com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
at com.pega.pegarules.internal.etier.interfaces.EJSLocalStatelessEngineBMT_f2439d86.invokeEngine(Unknown Source)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278)
at com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223)
at com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:574)
at com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:374)
at sun.reflect.GeneratedMethodAccessor164.invoke(Unknown Source)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
at com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:595)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:668)
at com.ibm.ws.cache.servlet.ServletWrapper.serviceProxied(ServletWrapper.java:307)
at com.ibm.ws.cache.servlet.CacheHook.handleFragment(CacheHook.java:562)
at com.ibm.ws.cache.servlet.CacheHook.handleServlet(CacheHook.java:255)
at com.ibm.ws.cache.servlet.ServletWrapper.service(ServletWrapper.java:259)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1230)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:779)
at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:478)
at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java:178)
at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java:1114)
at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.java:87)
at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:919)
at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1662)
at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:200)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink.java:463)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.java:530)
at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java:316)
at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.java:88)
at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionListener.java:175)
at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:816)
at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1881)
Caused by:
com.pega.pegarules.pub.PRException: Error mapping incoming response to .response_GET: java.lang.ClassCastException: java.util.LinkedHashMap incompatible with java.util.List
From: (H5342E6EF77140D20F7FC92489ECFB7C1:WPWD35JX.opr.statefarm.org)
at com.pega.pegarules.integration.engine.internal.ServiceHelper.setInboundJsonValue(ServiceHelper.java:1791)
at com.pega.pegarules.integration.engine.internal.ServiceHelper.setInboundDataValue(ServiceHelper.java:1594)
at com.pega.pegarules.integration.engine.internal.ServiceHelper.mapInboundData(ServiceHelper.java:1421)
at com.pega.pegarules.integration.engine.internal.util.PRServiceUtils.mapInboundData(PRServiceUtils.java:1259)
... 135 more
2015-09-23 09:38:01,281 [ WebContainer : 11] [ STANDARD] [ R21280:01.01] (nvoke.Rule_Connect_REST.Action) ERROR J30K-A4 - com.pega.pegarules.pub.services.InboundMappingException: Error mapping incoming response to .response_GET: java.lang.ClassCastException: java.util.LinkedHashMap incompatible with java.util.List
2015-09-23 09:38:01,281 [ WebContainer : 11] [ STANDARD] [ R21280:01.01] (nvoke.Rule_Connect_REST.Action) INFO J30K-A4 - Finished remote service invocation
2015-09-23 09:38:01,288 [ WebContainer : 11] [ STANDARD] [ R21280:01.01] ( internal.mgmt.Executable) ERROR J30K-A4 - Exception
Caused by:
PEG
Can you try sending the response as below.
Multiple Request:
Single Request:
[{"alias":"zzzz","caption":"","memberName":"HIs Name","title":"","license":"9b78","associd":"0"}]
Please share the screenshots of Connect-REST rule incase if this doesn't work.
Gangababu G.V
